AMDXPCottonFire22 said:Hrmm sandra rates it at 4686 MB/sgood bad odd wierd?
(cf)Eclipse said:Main System
Intel P4 3.2c @ 3.440 16x215
Gigabyte 8KNXP
6800GT
1 GB of Kingston 3500 Ram
from his sig. i guess the timings matter more, though i'm surprised the bandwidth isn't closer to 6gb/s at 215mhz. i had forgotten how much the ondie memory controller helps things out![]()
Correct me if I am wrong, but isnt bandwidth 'technically' measured in Hz? It is most commonly expressed in bps, but Hz is again, 'technically' correct.(cf)Eclipse said:um, by bandwidth you mean mhz?
i've never heard of a bandwidth of 217...
max theoretical bandwidth = mhz * 2 (ddr) * 8 (bits per clock iirc) * 2 (dual channel)AMDXPCottonFire22 said:well is says max overhead as above 6868 mb/s
