can i get 19" flat crt $200?
The term "Good" is relative, but yes there are some to be found.
Google it, be supprised ;)
BillR
I got a 21'' Dell Trinitron Flat Screen, It seems to be going out, Although it hasn't done it in a while, it's only when you leave it on for a very long time
It gets blury, then 5 mins later flicks back to perf resolution.
I might give it away for 200, and shipping.
well when you say flat it has to be a appature grille Monitor, No invar shadow mask monitors are perfactly flat. This is why companies like Samsung call there models DynaFlat. Thats is just how the technology works. On a shadow mask system the screen could not be flat or the left and right of the screen would not be clear. The electron gun would not be able to shoot the electron at the type of angle without interfering with others
Best Buy has a 19" Samsung for $199 (maybe $189 with a MIR), Circuit City also has this model. I started a thread on it, it looks good, but read my post in that thread, I coudn't get a good judgment on it.
i got a pair of sony 21" trinitron
medical monitors off of ebay
they were $125 each
thoughi got to drive to wonderfull gary indiana to pick em up
3 years later they still run great
ebay.
I bought a used 21" trinitron for $75... shipping was another $75 cuz the bitch is over 70lbs, but thats keeping under your $200 budget. Just do some shopping on there and you'll find a good one... I've had mine for 2 years and not a problem, no damage, no dead pixels etc.
