Can I extend my primary Win 7 partition?
Camberwell
I have a WD Caviar Black 640Gb HDD, it's partitioned into C: Windows 7 (104Gb) and D: Data (491Gb). I am running out of space on the C: partition and I want to extend it. The D: drive only has around 160Gb used space, and I only want to add around 50Gb to the C: partition. Is this doable?
I used GParted to shrink the D: partition by 50Gb so it is available, but I cannot see how to add this 50Gb to the C: partition. When you look at the disk manager, the free space is all the way to the right. Is there a way to shift this 50Gb to the left, so that I can then extend the C: into it? Thanks for any help!
You can move the partitions/unallocated space in Gparted as well as shrink/extend. (Though I thought it did that simply by extending. As in it was "smart enough". It has been awhile since I last used it.)
HOW TO "MOVE / COPY" PARTITION
P.S.
Note the g) sections screen shot. The "Free space preceding/following" sections.
