You can run -bigadv on that CPU with a bit of VM trickery, although if you were to go that route, I'd strongly recommend overclocking your CPU to at least 3.6GHz to ensure you meet the deadlines.
Can you? Yes. Can you while still running the 5850? Probably not due to the amount of CPU that card uses while folding and the fact that your processor is marginal to begin with for bigadv. Should you? Accord to Stanford, no you should not. Is doing it against the EULA? No.
If you do run bigadv on that proc, my advise is to not tell anyone about it around here. You will notice that we have no guides or anything posted on how to do it. There is a reason - it is a touchy subject around here.
to add, you NEED linux to do bigadv on thubans...my suggestion is to just do smp
Alright so I guess I will just do SMP and wait for bulldozer.
Sorry I had to do it.
http://www.overclock.net/overclock-...48365-ubuntu-setting-up-big-bigadv-p6903.html
Works for x6's and 2500k's as well... if they won't discuss it here, i know a place that will![]()
But you have no guides for it here. I know I used Musky's ubuntu guide when I was setting up linux on my 2600k, and it got me way ahead of any guide on OCN at the time.
But the tables have turned. The better guide is on OCN now (for single proc systems... Musky's is still the one for multi-procs). I'm just returning the favour to the good people of this site.![]()
but that's the big issue, number of threads means little now with SandyB, a 2500K overclocked to 4.5 is > 8 threads i7 920 at stock clocksThere are no guides for running Big adv/Big beta on anything other than 8/12 threads respectively because as a community the [H]orde is not a fan of doing it, so it wont be promoted....
we should have a portable bench mark utility, how hard can that be to impliment? it could be something like CineBench 11.5(I am not an advocate of using threads as a measure of system speed but it is what we have)
what I am saying is if a Big Beta WU takes about 5 days to finish and they usualy Fail at >90% if something goes wrong(unstable OverClock) what a small portable benchmark program that will not take more than 5 minutes to finish, what harm can that do? I am sure it will not slow the progect any more than what 4 threads SB are doing at the moment...
This has been a suggestion of mine since I become the DAB rep for the [H]. It would require coding for the mini bench, rewrites of the current sever code, along with the addition of another set of servers for keeping mini bench data/logs. All this with a project that is underway and shouldn't be stopped to put these changes in place.
Needless to say it is a bunch of work and resources that they don't have the time for currently. However as a long term fix to the current issues the DAB thinks this is a good idea.
I do not like that idea at all. I understand what you're trying to accomplish with it, but that would simply make it much too difficult for people to join the team.How about if WE implement this? meaning if you want to be part of any team you will have to use "This" Bench mark, if you don't pass the Big Beta test you will not be allow to fold under Our name...!
how about dividing the team based on hardware specsI do not like that idea at all. I understand what you're trying to accomplish with it, but that would simply make it much too difficult for people to join the team.
How about not dividing the team at all?how about deviding the team based on hardware specs![]()
I disagree. As it is, we actively try to discourage people from doing things that are detrimental to the project. More than that, it is Stanford's responsibility to keep things in check. Any attempts we make to regulate things ourselves will simply discourage new members from joining and drive people to other teams instead, which in the long run will not change anything other than reducing the number of members we have.Just saying...something needs to be done
Perhaps I should make an account on Overclock.net and try to recruit your members to our team. I'm sure the moderators there would love that.snip
Not cool, not cool at all.
how about dividing the team based on hardware specs.
wont happen again...The Team is divided enough as it is. Please do not suggest this again..
True...As for benchmarks.... doesn't Stanford already assign "Performance Fraction"? They just need to implement this number some way when making assignments.
edit.
a Overclocked i72600k can out perform a i7 970 also...
I should have said, that a stock 2600k will out perform an stock 970 here and there, not always and heavily threaded apps is one of them...Wrong Where are you getting your Information from I have not seen a single 2600K out preform any of my 970's yet. Care to provide a little proof of that. Or are you comparing apples to oranges and using a stock clocked 970. If you are I hate to tell you this but 970's can be OCed too.
so 2 QPI link makes them Westmere?970 = Gulftown, not westmere.
http://www.anandtech.com/bench/Product/157?vs=287
oh and sandyB can overclock alot nicer than westmere are capable of
Thank you Grandpa for schooling this noob,Sandy at 4.7Ghz
Project: 6903
Average time/frame: 0:48:41 {in hh:mm:ss}
CPU: i7-2600k @ 4.7 GHz
# of CPU sockets: 1
# of Physical cores: 4cores/8threads
# of FAH CPU processes: 1
# of FAH GPU Clients: 0
RAM GB installed: 8
RAM Type: DDR3
RAM Speed: 2133
OS name/kernel version: Ubuntu 11.04/2.6.32
Client: 6.34
Running in VM: No
Gulftown 970 @ 4.2 and 4.0
Project: 6903
Average time/frame: 00:42:57 {in hh:mm:ss}
CPU: 970 @ 4.2 GHz
# of CPU sockets: 6
# of Physical cores: 12
RAM GB installed: 6
RAM Type: DDR3 1800
RAM Speed: 1954Mhz 8-8-8-27-1T
OS name/kernel version Ubuntu 10.10 2.6.35.30 generick-ck
Client: v7
Running in VM: {No}
Project: 6903
Average time/frame: 00:43:13 {in hh:mm:ss}
CPU: 970 @ 4.05 GHz
# of CPU sockets: 6
RAM GB installed: 6
RAM Type: DDR3 1600
RAM Speed: 1920Mhz 9-9-9-27-1T
Client: v7
Running in VM: {No}
Not even close The a Sandy at 4.7Ghz is 5 min per frame slower than a Gulftown 970 at 4Ghz and all 3 of my 970's will run folding stable at 4.3Ghz 2 of them will fold at 4.4Ghz but I choose not to during the summer.
