my new build is becoming a headache. trying to run vista ultimate 32 and it's not going well
new stuff :
P5N-E SLI
core 2 quad Q6600
ADATA DDR2 PC800 4Gbs
old hard drive, WD 2500JS, vid card EVGA 7600 GT, Benq dvd drive
after playing around with the voltage for the ram, I manage to get this thing to work. I can load up XP PRO fine now and been using it for a week or so. decided to try loading up vista and it alway freeze at the "starting windows for the first time " screen. I've even left it for 3 hours. it doesn't make a difference if it's a clean install or an upgrade. same problem.
someone suggested it might be the RAM. I tried it with my old PC 667 2 Gbs, but no luck.
anyone have any other ideas I can try?
thx
new stuff :
P5N-E SLI
core 2 quad Q6600
thx
