Can Freesync work with Eyefinity?
MorgothPl
Just wondering, can Freesync be used on 3 monitors, or does it only work on single screen? if it works on 3 same screens, that would be very, very nice for my next build :)
I don't think they've mentioned if it's supported. Eyefinity works by configuring a single virtual display, I'm not sure if adaptive sync is possible in that scenario.
Maybe not at launch, but i'm sure it will be in a future driver release.
Keep in mind freesync requires DP. That might cause complications.
I have a feeling that Displayport will eventually take over DVI as the number one connection for video cards and monitors.
Since G-SYNC doesn't require a module in notebooks to work and possibly even in the desktop , I hope that this will cause all monitor manufacturers to include Displayport connectors on all new monitors. AMD did a really good job pushing for better scalar technology to come to the masses with their FreeSync initiative, and hopefully this means that everyone will benefit in the future. Just need to get those DVI connectors off the monitors in the future for more important tech.
Triple 4k Freesync/Adaptive sync monitors in Eyefinity :cool:
