Dew itt right
- Oct 28, 2005
Even if you crank down the CPU multiplier, can the CPU still limit your FSB overclock? I had an EVGA 680i LT with my current E6750 and no matter what I set the RAM and CPU down to, the board wouldn't even POST with a FSB over 440MHz. I have since upgraded to an XFX 680i board and I still can't post over 440MHz! So either both of these boards have the exact same FSB ceiling, or the CPU (or perhaps something else?) is limiting the FSB. I've tried at 1.4v and 1.5v FSB voltage and the chipset is watercooled. System is in the sig.
For example, everything runs fine at 438MHz FSB, 3504MHz CPU (438x8), RAM unlinked at 1066MHz. But if I try raising the FSB to 450MHz, dropping the CPU multi down to 7 (7x450=3150MHz) and dropping the RAM down to 900MHz (unlinked or linked & sync'd), it won't boot. I've also tried leaving the RAM at 1066MHz unlinked and nothing changes.
Any suggestions?
Any suggestions?
