Hi, I am looking to build a SFF PC and haven't messed with PC build stuff in a long time (5-6 years). I'm trying to get back up to speed as to what is out there and the best bang for the buck etc. and was wondering if you guys could help out.
I want this PC to be rather small to fit in a small apartment bedroom and not be too out of place (no neon lights, simple clean design). I would also like it to be quiet. I've been looking at cases like the Corsair 250D as it looks like an easy build, but a bit large.
1. What will you be doing with this PC? Gaming, Photoshop (or other intensive programs), Web browsing, strictly HTPC/Playback, etc. (If you have multiple things you want to do with the system, make sure you rank them from most important to least important).
I would like to do the following:
1. Gaming (DCS, Falcon BMS, Fallout, Battlefield, Civ V)
2. Video watching/chromecast streaming (live sports MLB etc)
3. CAD/FEA use (Solidworks, Abaqus or Ansys)
2. Will you be overclocking? (If so, are you looking to watercool?)
Perhaps, I don't want to have to keep tweaking it to be stable, but I've overclocked stuff in the past (AMD Athalons etc) so I am comfortable with the idea. No idea about water cooling. I would like this to be rather quiet under load and idle. Would water cooling be better or worse for that?
3. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
My budget for the PC it self is about $1500. I'm a bit flexible on this if it's worth it.
4. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
I'm near a Fry's and Microcenter
5. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need (especially if you will need 3.5" hard drives or expansion cards as these may restrict case options).
I don't have much to transfer over other than a crappy wired mouse right now.
6. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
I don't have much to transfer over other than a crappy wired mouse right now. I'll need everything for a ground up build.
7. What specific features do you need in a motherboard? RAID? Thunderbolt? Crossfire or SLI support? How many USB 3.0 and SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
I'm not sure what current technology I would really need since I've been out of the game for so long.
WiFi is required
1x SSD and 1x HDD required.
USB 3.0 would nice for future proofing I guess and external HDD use. I don't need RAID or Thunderbolt (I think). SLI/Crossfire isn't needed (is it even worth it at this budget)?
8. What resolution output do you need? 4k playback, 1080p playback, etc for HTPC or give a vertical/horizontal resolution for gaming SFF rigs. Do you need multiple monitor output?
Once again I've been out of it for so long I'm not sure if it would be worth it to get 4K support or do I only need 1080P. I wouldn't mind a widescreen wall mounted monitor.
9. Does this system need to fit into a particular space and do you need an optical drive? Think entertainment center shelves, closet space, rackmount, etc. Many modern SFF cases have either removed the optical drive or have been constructed so that removing the ODD increases the configuration possibilities immensely.
I can use an external optical drive when I need it. I would like this PC to be rather small as I don't have a lot of space. I would like it to not look too garish and lit up (would prefer non see through panels etc).
10. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
I'm ok doing any of these things. I have access to everything except a plasma cutter
11. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
Rather important. This is going in a somewhat small apartment bedroom.
12. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
Not very mobile. I don't plan on moving this until I have to move.
13. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
I have a legit Win 7 64bit key.
14. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
I would like to begin ordering parts/building this within the next week or two.
Thanks for the help
CPU (from my initial research it looks like Intel i5 is the way to go, but I'm open to other ideas)
CPU cooler
Case (was looking at the Corsair 250D, but if there are better options I'm all ears)
Case fans
GPU (was thinking around a GTX 970 or Radeon 390)
PSU (perhaps modular to make it easy to route wiring and work on other components)
RAM (was thinking somewhere between 16-32gb, mainly for dealing with Solidworks terrible large assembly performance)
SSD (I'm thinking something around 500GB)
HDD ((I'm thinking around 1TB for general storage)
Keyboard
Monitor
WiFi is required
Thanks for the help
