Can an Android phone work as Windows bootable USB drive?
colore
Hi
I want to install Linux in a laptop with empty disk.
What are my options?
Ideally I would like to:
1) create a a partition in the laptop
2) download the Linux Iso in that partition over WiFi or transfer the Linux ISO via a USB cable from a folder in an Android phone
3) boot/install Linux from there
Or I was thinking to create a partition in my Samsung S23 and use the phone as a bootable USB containing the Linux ISO.
Is that possible or anything easier?
PS: I cannot root the phone.
Thanks!
No, it won't work without root.
Without a spare USB drive of any sort, you'd have to make a FAT32 partition on the drive & extract the ISO to that partition in order to boot to it & move forward.
I'd be terrified what could be on the smart phone that would or could be transferred unintentionally, so please do the other suggestions above. :D
Thanks though the major limitation is not having a second laptop to create the boot USB.
I seem to be able to do it with EtchDroid app but for above mentioned reasons (security mainly), I wanted a standalone method using the empty laptop on its own.
EtchDroid will write the ISO to a drive w/o any security issues... Not sure what all of this FUD is about but make the bootable USB drive & test it.
If you have a Windows system, you can use Rufus or Balena Etcher to make a Linux bootable drive.
