Can all 845PE Intel chipsets do 800 fsb oc'd ?
NOL1M1TMAN
I seen like the Asus P4PE can with overclocking as well as the BH7 and a Chaintech board. So can all do it ?
Not all i845PE motherboards can do 800FSB. Nor can i845PE motherboards overclock above 533FSB without throwing both the AGP and PCI bus speeds out of whack. (At an 800FSB, the AGP bus speed on an i845PE-based motherboard would be 100MHz, with the PCI bus speed at a potentially damaging 50MHz! Those speeds are WAAAAY out of spec!)
In order for a "budget" single-channel DDR-based 800FSB-compatible Intel chipset to come out and replace the aging i845PE chipset, Intel simply took their i865PE and i865G chipsets and eliminated the second DDR channel link, creating the i848 and i848G chipsets.
hate to tell you this bud... but most 845pe boards have pci/agp locks and yes there are 845pe boards that do support 800fsb and they do lock the agp pci boards. go see this a one example
http://usa.asus.com/products/mb/socket478/p4pe-x/overview.htm
I stand corrected on that. But not all i845PE motherboards even provide an actual 800FSB (200MHz actual) setting. And there are a few that only provide 100MHz and 133MHz FSB speeds (400FSB and 533FSB, respectively).
