Can a Zero Insertion Force Socket be removed?
dylan
Thermo paste has gotten into a Zero Insertion Force Socket 462 of my motherboard thus causing a short that killed my beloved t-bird. Is there a way to remove the Socket 462 and clean the pins underneath?
Not without a soldering iron. And I strongly recomend against that.
Just a question, would alcohol with a toohbrush or pipe cleaner do it?
I don't think alcohol would hurt the board and would evaporate. It may help.
Either that or new board time.
Thermal paste...if you could flush it (for a while) with alcohol, you'd probably be in good shape. But that's a LOT of alcohol.
Try dripping a bunch of alcohol down there (soften it up a bit), then blasting it with canned air? :confused:
I've had this problem for a while I'm not letting some themo paste get me I'm going to use both alcohol go old walmart had a great deal on a liter :)
Radioshack has some electronic cleaner that looks good. Lastly a shopvac suck should get as much as I'm going to get out also it's more controlled that pressurized air.
Well now I only need a cheap socket A CPU to fry... I kill two already :(
Maybe you could find this stuff that gets sold as "contact cleaner", basically compressed hexane in a spray can. Comes out at high velocity, blasting away residue, and then evaporates almost immediately afterwards.
