am cleaning a friends vista 32 laptop out, it had some nasty spyware and viruses, but i was able to run combofix to get it back to normal, and removed mcaffe and AVG he had on it, and installed MSE.
i fixed all that but there is still the issue of no music will play, the audio drivers looked okay, but i un-installed them and reinstalled drivers, still nothing.
the icon in system tray shows a X in the sound deal, and it shows 0 for volume level, but i am sure the audio is set to work in control panel.
when i go to play something in WMP it tells me "no audio device availiable"
foobar2000 gives me an error as well, something about access is denied.
they had the same sound issue before i cleaned it out of crap, even system sounds do not work.
what am i missing here ?
i could format and re-install, but i would have to backup a bunch of stuff first
any advice ? ?
any advice ? ?
