Silversierra
- Apr 20, 2005
As the title states, my temperature readout in speedfan is 6C, (under load) while running orthos(and bios is lower, 2C, but bios isn't load temp). Is that even possible? The heatsink does feel cool(almost cold) to the touch. I'm running an e4300 @2.7ghz, and I am using pretty low voltage, 1.12V. I'm using the stock cooler (except AS5 paste), and have the fan speed set to max/always on in the bios. My other temperature readings(hard drives) are all around 30-35C, which seems more normal. So is 6C right, or is it not reading properly?
