Can a powersupply cause hard locks?
j3ff86
I'm trying to figure out the source of random hard locks in my system. They're random because the system can run stress tests for 30 mins then hard lock when idling. I've narrowed it down to the ram or power supply (2 year old Thermaltake 430watt). Has anyone ever had a power supply cause hardlocks, or am I looking in the wrong place?
depends? ive seen power supplies do funny things.
usually it will just cut off, or components like video cards give warnings not enough juice. or hard drives start dying as you put them in for a bit...it could hard lock it though
If you've narrowed it down to the RAM or PSU, then you could probably figure out which one is the problem by running Memtest.
If you were having lockups under load, then it could be your PSU not delivering enough juice. Lockups at idle don't normally point to power issues though. Is your OS set to go into sleep mode or some other power saving feature? It may not be recovering properly.
