Can a Go 6150 replace a GO 6100?
compudocs
Just purchase a rework station and was wondering if anyone knows if you can swap out a Go 6100 for a Go 6150 on any given board?
I have heard they are the same for the most part.
Just don't want to have to stock more than one chip if I can help it.
Thanks for any advice in advance.
I would worry more if the BIOS of said mobo is able to take advantage of the more robust features of the 6150 than if you can swap. Physically if the land pattern is the same between the two chips, you can swap, but electrically I cannot verify if it's possible.
One way to find out though is to actually make the swap and power it up.
I thought those GPUs were onboard? If so...then no they arent interchangeable...not even modular.
Youre talking about GO, the mobiles? If so then you should also specify what the interface is...as in some MXM or another OEM propietary infterface. More details are needed.
Actually, we do have a $3,500 rework station enroute that will allow us to properly remove then replace chipsets on motherboards.
Seeing as the 61xx chipsets are all based on the same manufacturing tech only with varrying GPU speeds and slightly different storage and networking functions it would seem they might be compatible but I am unable to find any precedance to base my guesstimations on.
Im not familiar with what a "rework station" is but at this point im assuming it allows you to de-solder IC chips and solder new ones in on a board? If so then im out of my realm of knowledge...and youd have to find the pin-outs from nVidia and the board manufacturer which i doubt youll obtain easily. However, usually if its the same series, in this case the Go 61xx series..the difference is likely clock or shader or whatever and i would expect them to be compatible.
The 61xx chipset series is a complete chipset solution like the old Nforce2 Ultra 400 Northbridge and the MCP-T Southbridge except it's all rolled into one, it's called a unified chipset. It handles more than the GFX, it's everything hence why when it starts to go or needs reworked, it generally needs replaced for a proper fix. Also the Go 6100 is for laptops and those generally don't have mini Pci-E slots if they are using a 61xx chipset.
I realized the Go/mobile-PCI/PCIe thing after you quoted me...if youll notice my actual "un-edited" response i pulled it out. :p
But yes i realize that its a chipset and GPU in one...but what i said i believe still stands and that for the Go 61x0 series...the advancements are usually just shader/clock oriented and not especially design implementation...chips are often designed for scalability...but either way...as i said before im a bit out of my realm. If it were me...id just spend a few bucks and try it out and see if it work.
