Can a chipped/damaged core kill a mobo?
Monroe_M
Got a question for all the AMD'ers on the forums.
Can an AMD CPU (e.g., Athlon, Athlon XP, etc) that is damaged somehow (like a chipped core) fry or otherwise damage a motherboard?
EDIT: To clarify, say I damaged or chipped the core of an Athlon XP CPU while installing a heatsink and suddenly the motherboard in which I installed the CPU in, suddenly doesn't POST. No beep codes, nothing. A fresh, undamaged Athlon XP of the same specs (e.g., 2000+ or an Athlon 900) also does not get the mobo to POST or sound any beep codes. RAM tests fine, PSU, HDD, etc.
Thanks in advanced fellas. =)
First of all,
Why would you wanna do that ? Install a chipped CPU on a perfectly functioning motherboard.
Yes, it is very likely that you ruined the motherboard by installing the defective CPU.
I'm not saying I did it, I'm just wondering if indeed, a damaged CPU can damage a mobo.
I'm personally an Intel guy (maybe not so much anymore w/ talk about the DRM thing in the Pentium D's) and as far as I know, it's a little harder to damage an Intel core (save for the SA Celerons or earlier chips) than it is for an Athlon or an XP. I was just curious.
I think the board would just fail to boot since the CPU was incapable of working. I would wager that the board would be fine.
But he said that he tried a working CPU and it didn't POST either.
Obviously something went wrong after using the damaged CPU.
Well, here's what happened (I probably should've posted this to begin w/, huh?):
My buddy brought his AthlonXP 2200+, his other 2000+, his MSI KT4AV-L and his Gigabyte 7VRXP v1.1 to me saying his 2200+ wouldn't work in either board after previously working for about a week and a half. He gave me the 2000+ to test it out w/.
So I checked out the 2200+ and it was definitely chipped, w/ the HSF showing signs of damage underneath. Neither board POSTs or sounds any beep codes but the CPU fan runs. I isolated the boards from all of his hardware and used some of my spare parts (RAM, PSU, switches, speaker, etc) that I all know work (took everything out of my test system that was powered on just 10 mins before) to test w/.
I set the boards on rubber mats and tested them w/ the 2000+ (which was in perfect condition) and no POST or beep codes. I tried another speaker, still no beep codes. I tried 3 different brands of RAM (2 listed as compatible w/ both boards), nothing. I tried w/ NO RAM, still nothing.
Reset the JP4/5, popped the CMOS battery out, let it sit, still nothing. Tested two brand new CMOS batteries, and still nothing.
He said he tried the damaged CPU in both boards which were working previously. My guess is that the boards were damaged somehow from the broken CPU as there are no visible signs of physical damage to either mobo.
So that is why I ask. :)
EDIT: Ah, BTW, I also tested his 2000+ in an older MSI board I have lying around (not sure which model off-hand) and it POSTed just fine, detecting it as an XP 2000+ as well.
I fail to see how a chipped CPU could kill a mainboard. Most likely those two mainboards were killed by this friend of yours or through another unfortunate accident.
Did you try this 2200+ in the working mainboard?
The worst thing a chipped core could do to a system would be causing a short, which the CPU voltage regulator circuit should deal with without frying itself.
If a motherboard did POST with that CPU then the CPU works.
The motherboards were probably damaged by something else. No idea what, but it's not the CPU.
if the cpu is shorted it can damage a mainboard, go to AMD's website, in the search window type in "RMA presentation" it should give you a link to a PDF that will tell you how to test the cpu to see if it is shorted.
Thanks a lot for the info fellas, I'll check out AMD's website.
BTW, no, the chipped CPU (2200+) didn't post (and sounded 5-short beeps in the working MSI board I mentioned that I tested it in) but the other working CPU (2000+) did.
According to what I could find about AMI beep codes, 5-short beeps means there is a CPU fault.
I've tested thousands of chipped or otherwise damaged CPU's in known working motherboards and have never killed a motherboard for doing so.
Why?
Many people have returned CPU's to me for "warranty" when in fact they had damaged the CPU in an effort to CRAM a heatsink onto them. Of course, when I tell them that their physical damage voided their warranty, they naturally want to know if I can bench test it hoping that somehow the CPU survived. 95% of the time, the CPU is in fact dead as a door nail, but like I said... never have I fried a board with one.
Now, I HAVE had BAD CPU's kill motherboards. But that had NOTHING to do with core damage. The core could have been damaged or not and those boards would have died with that CPU in it regardless
Said your buddy brought you the mobo's proc's? You said you tested them on rubber mats? Sounds to me your friend didnt think much about traveling with computer parts, did he just take them out or put them in anti static bags or wut? maybe he did something in route to your place? :p if im wrong its cause that is a long story but i think i got the jist it :p
soulsaver_8229
soulsaver_8229
One mobo was in his case at the time he gave them to me, the other was in it's original box in the anti-static bag.
Thanks so much for all your help so far guys.
i had an older epox board that wouldnt post for me at one point in time after i chiped a corner of a core, took every thing off the board disconnected the power header, reset the cmos and then took out its battery just to be shure that was a done deal.. waited about 30min... put the battery back in and reconnected the power header and hit the powerbutton with nothing more than a pc spoeaker and fan on the cpu headed... no cpu no ram no vid nothing else... let let up the led with no cpu found codes, shut it down and put the cpu /heatsink back on.. hit the power button and it gave me no ram found... gave it ram and vid card... it booted and ran for about 3 min/s then it blew 3 caps on the mobo, replaced the mobo and it ran fine for about 8 mounths befor i replaced every thing with what i have now about a year or so ago...
so try booting the system whit absolutly nothing on the mobo at all and see if they will give you any beep codes.. when i thought i had kille dthe board it wouldnt give meny any beep codes till i booted with nothing at all in the board..
its worth a shot..
thore
Update: upon closer inspection, it seems that his PSU might've blown. the CPU and VGA fans still turn on (still no post or beeps) but he has two fans in his PSU; one is stalled and the other is barely spinning.
I tried both boards w/o CPU's, no beep codes. I tried w/ my working PSU of course. Tried it w/ just the CPU fan plugged in, the PSU, and the power switch and the speaker.
It may be the PSU, I'll have to call him and ask him exactly how it died on him.
EDIT: the PSU is a "Power Magic 550", according to the sticker, the rails are well within range but I've never heard of this brand before.
You mean that this PSU might have let out the 'magic' smoke? ^_-
Ratings mean nothing. Especially with generic PSUs, like this one, they're usually inflated by a significant amount. They also have a tendency to have unstable/too high/too low rails, in addition to an affinity for blowing up for no apparent reason. Test this PSU with a DMM if you want to be certain it's dead or malfunctioning.
I'd say that it's infinitely more likely that those mainboards were killed by a faulty PSU than a chipped CPU :)
Yeah, now that I've seen that the PSU fans have died (only one barely working like I said above), that's my suspicion as well.
Thanks to all who replied, [H]Forum members do it again. ;) I can now tell my buddy what happened.
