I've got two Acer GD235s and one Acer HN27. The 27" has a built-in emitter, but the Nvidia software won't let me sync up the two smaller Acers using that method. It asks for the USB version of the emitter. Even if I had that, I assume that in turn wouldn't work on the 27".
If this is par for the course, how the hell do you hook up three versions of a monitor that comes in both the built-in and non-built-in flavors? For instance, I ordered the Asus VG236H, which has built-in emitter. Will that not function in 3DVS with Asus VG236 regular, which does not have emitter? And if that does work, why can't my current combo of monitors get running in 3DVS?
Should I cancel my order and put in for a regular VG236 and a USB emitter if I want to use it with other identical and non-identical 3D monitors in 3DVS? Or will even that work only with identical monitors?
