Can 2001FP do 1600x900 unstretched?
If it can, then I would buy a 2001FP over 2005FPW, since I'd be able to play HL2 using 16:9 instead of 16:10. AND have the full 1600x1200 res in windows.
Can somebody with a 2001FP test 1600x900 in HL2 using and tun off stretching?
i assume you could do it in windowed mode or with bars on the top and bottom, but other than that i don't think it would be possible.
How much do you care about size, weight, and LCD-ness?
If gaming is your primary concern, there isn't anything like one of these 92.6 lb monsters.
And no, I'm not selling it. I just bought one from these guys for $478 shipped & it's absolutely gorgeous. I run HL2 in 2304x1440 on it on my GF6800GT. It's 16:10 natively, but being a CRT it has no problems with 16:9. 4:3, and 5:4 modes. You just tweak the image size controls to leave part of the screen unused.
As for the 2001FP, worst case you'll have to run it in a window. I wouldn't get a 2005fpw over a 2001fp just for this. The 2001fp is cheap right now (unless that $600 sale ended), and it's simply bigger than the 2005fpw. 1680x1024 or whatever just isn't as much as 1600x1200. 16x12 = 192 square inches, and the 2005fpw is about 17x10.5 or something like that, so more like 180 or so. Then the 2001fp has more pixels, 1920000 vs. 1720320. The 2001 is a solid 10% bigger. So the 2005fpw is smaller and costs an extra $150.
If the 2001FP can't do 16:9, then I'll settle for 16:10 on the 2005FPW.
I'm fine with the loss of resolution going from 2001FP --> 2005FPW, but I won't buy the 2001FP if it gives me an disadvantage in DoD:S!! :p
