silverphoenix
- Feb 15, 2006
Can anyone measure the height of the inside of the 5.25" bay area. From the bottom of the inside of the case to the top of the inside of the case.
Thanks
Thanks
I think he meant bay area of the case where you place the 5.25 devices. Probably measuring for triple rad setup. Am I right?
You can JUST squeeze a mcr 320 into the front of a 900, however this will leave you with 0 room for your optical drive .. that would include a slimline mod as the room below the lip of the drive rack would be ocupied by the Nipples of the rad. I test fit this on mine and did not like that idea, so I am in process of building a foot for the radiator (See project cheapskate in the worklog forum) to sit in rather than hacking a side fit optical solution.
