EvilAlchemist
- Jan 11, 2008
*cough* 3.9 weeks *cough*
Back to 1.3 Months ....
I think you say it best
*cough*
*cough*
I see....the Force is strong with this one.I guess I'm going to have to quit coasting and put it into overdrive...This does kind of remind me of a couple weeks ago when Sunin kept flashing up in my rearview mirror, seems like he and I were around the same point difference then, and I had to pull away from him.
Firing up the Deep Purple and tightning up the straps!!!
LOL that won't be for long Axdrenalin! My 4th Q6600 goes online tonight. I also bought 2 more TRUE's to ensure my OC's on an older Quad and this new quad hit 3.6Ghz stable. I'm still waiting on buy.com with my 9450. If it doesn't ship this week I'm buying a Q6600 just to hold me over... which will be water cooled!
So my 12k PPD avg should be jumping to around 20k within the next week... Bigger Steam Roller!!!
Plus I'm addressing my network stability which should allow my base 12k to truly produce the 17k per day AVG it is capable of!
I see what you did and I will up the ante with 4 Q6600 at home + a few C2D computers at workI might even get a Q9450 for my main PC (I'm currently hunting for a 2x2GB Mushkin Redline PC2-8000 so I can run at 3.6 8x450 and beyond). However, nopt sure about when since I'm putting the final touch for my new condo that I will be buying.
Thinking about that, are you my alter ego ??
Funny thing is I am also saving up to buy my condo I am renting currently... so um that is scary! This is also it for me for a year! Unless my bonus or tax incentive check is just too much to resist.
Ah screw it, just ordered my 5th Q6600. I figure I can use it on my Gaming rig until the 9450 comes then transplant the Q6600 into my HTPC and sell off the E6600 to someone here. Its lapped, it runs cool at 3.6Ghz, I'm sure someone will want that Dual core... I'd even sell it dirt cheap to someone like Crazy Larry Since he seems to be very froogle! But he would have to promise to get a TRUE and use it at 3.6Ghz
Or at least beef it up which I did today. Installed a linksys RV016 Router. I'm going to disable DHCP shortly and start manually assigning them. I added a 4th Quad last night and I'm in the middle of installing a Q6600 in my HTPC and moving the E6600 into the 780i mobo until the Q9450 arrives.
Managed to do the network router switch over without losing a single smp
Right now it is showing 18892 PPD via FahMon +900 PPD PS3 (19800PPD) with several slower work units and that does not take into account the HTCP changes which are in process. I'm hoping to be in the 20-24k range based on a random sample of WU's by the end of the day.
Bringing the Heat!
Where's your new box with that cheap motherboard my cousin sold you?
It's testing right now with a lapped e4300 @ 3Ghz, I'm double checking stability and temps. I really need to get me a better HSF to put on the CPU at those temps though, because it runs constant 66-67C with the one I'm using right now, which I'm a little uncomfortable with. Once I get those things worked out and running stable, I'm going to be loading up Linux and cranking another SMP on it to fold with.
Its pretty impressive for a budget board.![]()
What about ram? did you go with 512Mb or 1Gb to keep with the budget theme? (seems like you have a ram overkill with most of your boxen)
You know, I'm getting sick and tired of this database error crap...What's going on with the forums lately????
At 800,000 points per month, its going to be hard to compete with Axdrenalin.
Ax how many PC's do you have folding now? Or how many Ghz, if you added up all the cores, etc?!
