I'm sure this has been asked a shit-ton of times, but it's difficult to find exactly what I want (reading through 60 or so pages of threads over a couple hours really gets to you)
but: if you're air cooling, what's your cooler preference? I hear lots of people use the Thermalright XP-90/120's. What kind of fans do you use with them the majority of the time? Anyone using an AX-478 cooler on a prescott with good result? Is there any moderately priced air cooling solution that you would recommend above all other air solutions?
(I've got a bunch of swiftech stuff and heater cores and an eheim pump and all kinds of lovin', but i need 100% safety until I start working at home again--not worry about springing leaks [even though it's relatively unlikely if assembled appropriately..])
Thanks a bunch,
Chris
Thanks a bunch,
Chris
