Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Specs in sig.
CPU: ~39-42 idle (depending on room temp.) highest=45
GPU: ~42-45 idle (depending on room temp.) highest=55
Highest temps for cpu only achieved during benchmarking. Highest GPU temps achieved usually playing games (ie: Oblivion/NFS:MW/F.E.A.R., etc.) Idle temps are taken when fans is on auto (koolance speed 4 or 5). Highest temps are on fan speed 10. I'm running a PC3-724 with a 10mm Koolance CPU block and a 6mm Koolance GPU block.
