Calibrating LCD screens
Tony Montana
The other day i got my first LCD a 19inch wisdescreen Samsung 940BW looks great but i tryed using adobe gamma to calibrate it but im not sure its working like it should on a LCD monitor.. any suggestions on howto properly calibrate the monitor via ONLY software>?
I've found that this is fairly easy to use and produces good results...it even lets you save a color profile to load with windows.
Tony Montana said:
thanks much.. it is possible to display a higher res then 1440 900 on my screen?
Not if that is the maximum...you can go lower but it won't look very good.
