Caffeinated
- Oct 16, 2002
I've always wanted to build a system like this, but I've never been a fan of the aesthetics of huge cases. I guess it is because I've worked with servers for a long time, and few things are less attractive than a 137 lbs. beige box. I know that towers are better looking these days, but I wanted something that didn't take up much space. Enter the Microfly that I picked up on sale.
This particular project is built with speed and cooling in mind, not noise reduction, as you will soon see. Most interpretations of SFF systems have been small and quiet, but my reason for going SFF is for space saving and aesthetics.
The specifications of the machine are as follows (also in my sig, but I will put them here for the sake of completeness):
Microfly Case
HEC 585W PSU
AMD X2 4200+ @ 2.63 Ghz 1.40 V
2GB G.SKILL PC6400 DDR2 (@ 745 4-4-4-12-1T) 2.0 V
PNY Geforce 8800 GTS @ 535/905 (1810 effective)
LG Electronics 18X DVD±R DL DVD-RAM
Maxtor 7200 RPM 300GB IDE
(3) Sunon 40X40X28mm 13000 RPM fans
Silverstone 92mm Var. Speed Intake Fan
Ultra 120mm Exhaust Fan
I need a new HDD to be honest, as I'm not thrilled with having an IDE drive in a new system, but it's the only one that I had that wasn't in use. Hopefully I'll get a better drive soon. As you can see, I have upped the voltage on my CPU and RAM in order to get a stable overclock. I'm not a fan of "suicide" runs and instability; what you see listed is where it is currently running. I have a couple of temp and stability test shots that will follow. Note that this isn't specifically a woohoo, overclock it until it drops type of project, either; I wanted a stable and fast good looking box, and so far, I think I've achieved that objective.
On with the pics
Box with no covers HDD side
Box no covers Graphics Card Side
The Microfly top with the Acrylic Panel in...won't be there long!
My painted machine screws and washers drying in the sun
Screws and washers I used
Snipping the hardware cloth to size
Hardware cloth drying
All 3 panels, with the new screened in sides
Another shot of the finished panel
Front and Top view with the new screened in panels
Graphics card side
Hard Drive side
Top View
Stability/Temp screen shots will follow later. As you can see, though, for an overclocked SFF, I have plenty of air flow now that there is the open air of the screening. I used 1/4" Hardware cloth picked up for $3 at Lowes, machine screws, and some black paint I had sitting around. I'm pretty happy with the way it turned out, especially for a mod that material cost was about $5 and time
Microfly Case
HEC 585W PSU
On with the pics
Graphics card side
Hard Drive side
Top View
