cache vs. rpm
aggr1103
Simple question for someone trying to get a better hold on drives, loadtimes, and speed.
Looking to buy a new drive. Size of the drive really doesn't matter too much, but I would like to see some sort of speed increase both in boot time for xp and load time for games and whatnot.
Would a 7200rpm 16mb cache hard drive be a better choice than a 10,000 rpm 8mb cache hard drive, for one, or both of the reasons stated above.
My only experience in upgrades with hard drives came when I went from a 5400rpm hard drive with unknown cache to a great western digital 80gig with 8mb cache at 7200 rpm. I noticed a great difference in load times and boot time. I'm presently using a 160gb 7200rpm 8mb cache hard drive and haven't noticed a difference.
bump? Nubbish question I know...but I would like some help getting an understanding.
The cache part of your question is tricky, it depends on what gets cached.. That can vary from drive to drive.. A 10k rpm drive will generally give you better random access and overall read/write speed than a 7200 rpm drive.. In my experience it was a noticeable, but small difference in every day use.. A few seconds here and there shaved from boot times, app/game load times, and level loads during gaming..
In the end I prefer getting 400 and 500 and now sometimes 750gig 7200 rpm drives for the same or lower price than the 150gig 10k rpm raptorXs..
For a work env with lots of building of applications where lots of small files need to be accessed very fast, i noticed a tr emendable increase in speed going from a 7,200 rpm drive to a 10k rpm. As for read and write speeds for copying files things seem around the same. I would recommend the higher rpm drive. Not sure if you'll notice much of a difference in games though. Boot times seem to have went down a noticeable amount as well
RPM and cache size do not uniquely determine a HDD's performance. How am I supposed to tell you which is the better choice without knowing which HDDs you are comparing nor what price each option carries?
Of course, I could take an educated guess that the 8Mb cache 10k rpm drive is a WDxx0GD drive, but even within that family there are some rather `major' performance differences if we are to believe what Storagereview writes about them.
I'm not even that far into the decision making process yet. I want to get a general understaning of performance beneftis of each. So far, I'm getting an idea, then I will come back with options.
