Cables
Hulk
Where can I buy a 30 FT USB cable?
What's the longest USB cable on the market and where can I purchase it?
Id check monoprice out first, they have some 15ft USB 2.0 A to A Male/Female Extension Cables that you can keep extending or just run of the mill 15ft usb cables
doing a quick search didn't find anything in the 30ft range though, what do you need a 30ft usb cable for if you don't mind me asking?
with length limitations considered, could the OP use a powered hub in the middle to help with that limitation?
