_Durandal_
- Jan 19, 2003
A client of mine called me with a question regarding his RoadRunner internet connection. He has the 5Mbps service, for reference. When he runs different online speed tests, he gets different results based on which computer the test is run from.
For example:
His invoicing computer and the kids PC both run the following tests perfectly...4.5Mbps
http://www.aroundcinci.com
http://www.dslreports.com
http://www.bandwidthplace.com
http://speedtest.wi.rr.com/
Now, if he runs this test from his desktop PC, the results from the RoadRunner test site are perfect, yet all the others report that he is only topping out at 2.5 or 3Mbps. Any clues as to why this happens?
I should note, that recently, I was out there working on his PC's and noticed he was only achieving 1.5Mbps on all of his computers. We called Time Warner, and they determined it was a problem with the cable modem itself. Now, since the replacement, things are better, but not what they should be (according to the sites above).
All of the computers are similar in specificatios, spyware free, and are not running any sort of firewall software (other than the one installed with Windows XP's SP2). The only thing in common is they all pass through a Linksys SRX200 router, but if two of the three PCs can pass the speedtest, why cant' the third?
So, my only guess would be network card drivers, or just a NIC not functioning properly. Any other ideas or suggestions?
Oh, I should note, that he tried to run these tests on a wireless laptop and I was under the impression that he would never achieve a 5Mbps download rate using wireless...not entirely sure though, so that's why I'm asking.
For example:
