Hi guys, I was checking out https://www.moddersmart.com, and I am not sure how much cable sleeving I need, and what sizes I should get. I want to sleeve the entire system, every single cable, and all 3 water loops, 10 hardrive satas etc, and I will pin remove to sleeve each individual molex/3pin cable.
I also saw the http://store.murdermod.com/murderware/sleeving-kits/murdermod-mdpc-x-psychopack.htm Kit, but it doesn't seem to have everything I would need, although I could buy 2 of the kits, and that should be enough.
I obviously have seen the http://www.million-dollar-pc.com/, and would like to sleeve it as well as those guys have. I have around 2 whole days to sleeve, so hopefully with a little luck and the right parts its doable.
Feel free to suggest anything, I am not to picky, doesn't have to be "OMG" you can't see anything through but that would be nice, I mean I used sleeving from various grades, and I know some are better than others, but I am looking more for practicality, and am on a budget. I would like to spend no more than $100 total on the sleeving.
Thanks!
Thanks!
