Cable Organizing and Fan Grilles
burningrave101
I've got an Antec 1080 case with a side window panel and i need some suggestions guys.
It has an Antec True Power 430w in it and the wires are a mess. I saw this site listed and they have pretty good prices on wire loom and zip ties.
http://www.cableorganizer.com/cable-ties/
4" zip ties are probably what i need right?
http://www.cableorganizer.com/wire-loom/colored.html
What size wire loom should i get? 1/2" or 3/4"
I'm leaning towards the 3/4".
[Also does anyone know where to get the gold colored fan grille's? I seen the chrome colored ones on SVC but those aren't what i want. I want the gold looking ones like on my Antec PSU and like alot of you fellow modders have on your case fans.
Lastly i'm going to be putting 5 case fans in my case and i've decided to go with 2 CCFL's instead of LED fans so what case fans would you suggest? I want good cooling but not extremely loud.
Nobody ever lists the fans and stuff they are using in their case when they post pictures lol.
Just so you know, the CCFL fans are nice, but BLINDINGLY bright. I have one on exhaust and the rear of my computer faces my bed. I had to move a desk in between the computer and my bed, it was actually making it hard to sleep. I have a switch on the thing but it got screwed up and I've been too lazy to fix it (modder's malaise). I could actually see the light through my eyelids from about 7 feet. If you don't have direct line of sight they're fine though. I wouldn't put one on a window, they're just obscenely bright.
In regards to the wiring, learn to hide the wires behind the mobo tray, behind the psu, around the edges, etc. If you look in the FAQ there is a very good tutorial about hiding the wires. I would try that first before going through the trouble of looming them.
And I wouldnt use this wire loom. I would recomend this:
Expandable Sleeving
This is much more flexable and looks a helluva lot cleaner than plain plastic wireloom.
If you have the time and patience sleeve the psu cables with some uv reactive sleeving. It looks SOOO much better than loom or ties
what i did with mine is fed the wires through the right side of my case where a hole was and duct taped them to the right side, funny thing is it actually works and looks neat if you get the right side of your case to fit on, which i can do :D
Originally posted by burningrave101
Well i was going to just do something like this:
http://www.viperlair.com/articles/retired/int_antec.shtml
The link to the cable hideing guide on Twisted Mods site is down because their site got hacked.
I think i might try the 1/2" wire loom. Its $13.50 for 20'.
Any recommendations for case fans and where can i find these gold grilles?
Dude, no offense, but the final product in that guide still looks like crap compared to a good hidden wire job. Seriously, hide your cables behind your mobo tray as much as you can, and the rest go up the side behind the mobo tray and hd/cd bay trays. I good hidden wire is better than a visable loomed wire.
Alright i'll try that out first. But are there any good guides that show how to do all of this? I seen one a while back and i think it was the one on Twisted Mods but that link is dead.
There is this one, but it involves using dremel tools which i dont plan to do but i suppose i can use some of the other ideas from it.
http://m6.hwgn.net/articles/cable_clean/index.shtml
Also i still need some ideas on brands for case fans and where i can buy those gold colored fan grilles please.
There was a really good one posted on HardOCP's news page a while back - Sadly, I lost the link as I am currently looking for it myself also.
Hrmm I have also been meaning to clean up my wiring.. but the wire loom seems too tedious.
The concept of hacking precise holes into the mobo tray is scary since it was planned so well... too lazy to do that.
One of my problems is my case doesnt let me take the right panel off, so I loose a world of hiding places. The mobo tray is the entire back of hte case.. weird case.
If the case had no windows... then there is no need to be concerned about wiring :D
Um........ can you say "wrong!"? I knew you could :)
Clean wiring decrease air restriction and promotes good airflow, which as we all know is essential for proper cooling. I've seen temps in cases drop 5-10 degree's simply by cleaning up the wiring and getting a proper air flow.
Nobody knows where to buy these gold colored fan grilles? Half the computers in the Gallery section use them! Comon guys i need to order these things by tommorrow lol.
And what brand of case fans are you all useing? I know panaflo is one of the best but they are also pretty expensive for 5 of them.
I found the gold colored fan grills and they are $2.50 each. I dont guess their cheaper on some other site? Probably not. Their twice the price of the chrome ones i see.
What about case fans guys? I havn't even had one suggestion on what your using for case fans yet!
You answered your own question! Panaflow. There is little else that has the flow and silence of the Panaflow fans. Just bite the bullet and get them. You will not be sorry in the long run, and they can always migrate forward into your next project should you have a need.
Ahhhhh... The sound of silence.:D
Use a Techflex or Vantec wire sleeving kit instead of wire loom. Hiding wires in an Antec case is easier said than done due to the lack of room behind the motherboard plate and the right side of the case, so some wires will be visible no matter what.
As for fans, the Vantec Stealth jobbies are nice and readily available, and unlike Panaflo fans, won't require tailing to plug in. If you can find them, the NMB fans are even quieter, but I haven't seen then at an online shop lately.
I decided to go ahead with 5 Cooler Master neon blue fans from Newegg. They are on sale today too. But that didn't really matter because I ordered five of them so i got them for $6 each and free shipping.
Also, here is a found roundup that was posted today. I listed 4 of the really quiet case fans that do a good job of cooling.
http://www.extremereviews.net/data.php?recordID=104&page=1&type=review
Papst fans are usually known to be better then Panaflo's but more expensive.
I was thinking of getting that Antec Sleeving kit but now I will try the hiding method...Are there any good links? The ones listed don't seem to work...
