Ok...here's the situation...
I have 3 machines hooked into a d-link wireless g router. 2 are via LAN cable, the 3rd by wireless. Router is hooked to Cable modem. All works ok with that setup.
Here's where I'm having some issues...
The same line that the Cable comes in on, we also have Satelite. starting from outside:
Outside:
Cable Line + Satellite > Diplexer (combines cable + satellite into one cable for entering the house) > single RG6 into house.
Inside:
RG6 > Diplexer (seperates Sat and Cable into seperate lines) > Cable and Sat.
On the Cable output of Diplexer, it goes to a splitter and splits to Cable modem and Cable box. Satellite output obviously goes to Satellite reciever.
That setup doesn't work.
What happens is that it all works fine...until I plug in the RG6 to the Satellite reciever. Once I plug the satellite receiver in, the Cable modem drops.
Is there a solution to this? I'd prefer NOT to make everything wireless since one of the PC's is an HTPC. The next closest "open" cable line is upstairs, and my wireless signal drops in half if I move the router and cable modem up there.
Are there diplexers and such that work with a cable modem? I suspect that the cross-traffic from the Satellite's LNB and the bi-directional data from the cable modem are interfering with each other.
Outside:
Inside:
