TheOneGreatX
- Oct 1, 2005
I have seen people taping cables to the side of their case. What kind of tape should be used for this?
See Footer4321's link for tape that doesn't leave a residue. I work in the food processing industry, and we use spike tape when we're working in some of the clean rooms that requires a non-residue tape.SpangeMonkee said:don't use tape. it just leaves a sticky mess after a while and if you move some cables or add another device, you have to peal it up and it just becomes nasty.
