The two cables loose at the top are for the fans. For reference the parts are:
xfi xtreme music
x1950pro
floppy
dvd drive
965p-ds3
I still have to connect the harddrive at the bottom, and hook up the fans.
Is it ok to have the cables resting on the video card like that?
Also, to hook up the fan at the bottom, is it ok to just hook it straight into a 4-pin connecter that branches from another cable? or is that too much power? I only ask because the ones at the top have a connecter that says FAN ONLY.
