Cable Management for TJ07
Nirad9er
What is the best cable management / routing for the TJ07 without doing any modding? I want to redo my cable management and was wondering what other TJ07 users are doing?
8pin motherboard
24pin motherboard
sata power connectors
sata connectors
PCI-express cables
Please post pics if possible
Thanks
I'm wondering the same thing, trying to figure this out for my new build. I've seen many route 8 pin and 24 pin behind the mobo and cut holes for cable management. PCI cables I've seen are usually just stuck up through the holes in the mid plate. Don't know about the rest. I read something that says since TJ07 standoffs are taller than usual, you can route under the mobo as well.
depends on which version of the board you got
if you got the new one with the backplate cut out for the xeon board you can chuck stuff under the board and then plug it in for like 24 pins and 8 pins
for gpu you might want to add aditional holes
