Cable Management Case up to $300
OliverBGD
Hi,
I currently have Thermaltake's Armor and even though its a spacious and nice air cooling case, I want to throw it out of the window due to its poor cable management. Thus I decided to buy a new case, so my question is which case would you recommend for very good and easy cable management that costs at the most $300?
One I've recently seen that i find attractive is the coolermaster 690. The cmstacker and antec p182/190 also looked easy to work with.
*edit*
Im using a sonata II btw. I spent an hour managing my rat nest.
check out the lancool K7. it has a pretty nice cable management system as the motherboard tray already has some holes cut into it for routing cables around the back. the back of the tray also has built in clips for holding down cables.
I second the cm690.
if you don't mind cutting the case, the Centurion5 is a good choice.
My P180b looks super neat, but I've modded it a little.
Lian Li's are rockin' cases
