Hagrid
- Nov 23, 2006
I built a miner cabinet from a cabinet I bought on Amazon.
https://www.amazon.com/gp/product/B004HLU7CE/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
It has a 18n exhaust with fan which will be attached to the ceiling. The intake is through a 14x25 air filter housing. The wiring is 6ga 240v which is on a 50a breaker. The sub panel has 3 15a 240v breakers. The 50amps would give me 9600 24/7 wattage. Each 15a will give me 2880 safe watts. I will have a rack inside to hold the video cards and the motherboards will be attached to the side of the walls. This will allow air to flow up from the bottom. The bottom fans will be 2 12" high flow fans. I also have another 2 that I can install in the middle. I have the main breaker and wiring installed I just need to move the cabinet over tomorrow and hook it up.
I put in 6ga wire which should handle 60a but I do not need that much wattage, so 3 15's will suffice.
My son decided not to mine so he sold me his cards. I put 8gb on each machine just because I already had 4x4 ddr4 sticks and bought 8gb more.
I will run 5 1080ti's on 1 plug, the rest will go on the other 2. I might get another Asrock ab350 pro 4 combo for any extra cards I can get. I run 5 on each MB about right now, but in different areas of the house.(dont want to overload 1 circuit)
I also have a 20a 120v breaker that will be dedicated to it as well. It is already there since it was for a fountain. I just have to pop it through the wall. This will run the fans and stuff. The 1060's sip power and can run 5 on a 850w PS no problem. I only have all cards at 70% power limit. I am not sure if going over that will result in a lot more.
I will have some pics when I am done with it.
Asrock AB350 pro4 mb, Ryzen 3 1200, 8gb, 1600w EVGA Platinum, 60gb SSD
Asrock Ab350 pro4 mb, Ryzen 3 1200, 8gb, 1200w EVGA Platinum, 60gb SSD
1 Gigabyte x99sli motherboards, 5820k cpu, 1000w EVGA Platinum, 240gb SSD
1 Asrock Extreme 3 gen 3 mb, 2500k, 8gb, 850w EVGA Platinum, 60gb SSD
5 1080ti hybrid, 10 EVGA SC 1060 6gb, 2 1060 3gb, 2 XFX 580 8gb
PCIE extenders.
PCIE extenders.
