C70 fan orientation with H80i?
Krieger91
How should the fans be set up for this case with an H80i?
I was thinking something like this:
Two intake in the front, two exhaust on the top, two intake on the side panel, h80i in exhaust.
Also, since I don't have any dust filters for the side intakes, could they be exhaust?
Yeah the best should be to put the h80i as exhaust you will loose like 2 degrees on cpu cooling performance but that will keep the overall system parts cooler.. For me that worth... As this case have 2 mounts on the HDD bays you can put just one fan on the side panel (the top one). I use this way with my h100i and work perfect... I also removed the supperior HDD bay, and put a cooler master sickeflow on that that space just above the bottom HDD bay, this allow superior airflow (and less noise). Over the Gpu in the front of the case i put 2 of the fans that comes with the case. So the fan above the bottom HDD pull more fresh air.. This its the best cooling performance and airflow i found in this case.... I'll post a photo later (im on right now on mobile phone)..
