Your right, the effective speed is double of the FSB. So I'm running 400 FSB using a 1:1 multiplier then the ram would be at 800mhz which is the effective speed.keldegar said:i could be wrong but i think it's like this:
DDR is double data rate..
so the memory is at 400mhz (1:1) but it's "Effective" rate is 800mhz because it's DDR.
MrFace said:Am I seeing this right...that you can run CPU at 400mhz FSB, but run memory "1:1" at 800mhz(quad pumped)?
How does that work? Wouldn't that be 2:1 CPU:Mem????
