c2d E6300 & GA965P-DS3 Overclocking Problems
Andyp33
I have had some good advice from BillParish within this forum. However, I still can't manage to overclock more than 2.1 Ghz. The dam thing keeps booting almost reaching POST then re-starts itself. I then go in check the BIOS and the CPU Host Frequency has reset itself to default (266) dissabled! Has enyone got the same board and CPU as me with a good overclock that I can try PLEASE.Otherwise I am gonna buy a Q6600 and forget this Overclocking lark (about to give up)
Gigabyte GA965P-DS3 (BIOS v.F12)
Core2Duo E6300
2 X 1 Gig Patriot Memory Extreme performance 6400
Nvidia 8800gts
you need to post your settings or copy/paste this and fill it in, resetting to default on a gigabyte board simply means you have your overclock settings to high or something not set high enough.
Fill this out and we can better help you
Code:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster___________ Turbo
CPU Clock Ratio (Note)____________ 8
CPU Host Clock Control_ [Enabled]
CPU Host Frequency (MHz)__________ 450
PCI Express Frequency (Mhz)_______ 101
C.I.A. 2__________________________ [Disabled]
System Memory Multiplier (SPD)____ 2.0
DRAM Timing Selectable_______ SPD __ [Manual]
CAS Latency Time_____________ 5 ____
Dram RAS# to CAS# Delay______ 5 ____
Dram RAS# Precharge Delay_____5 ____
Precharge Delay (tRAS)________15 ____
ACT to ACT Delay (tRRD)_______4 _____
Rank Write to READ Delay______3 _____
Write to Precharge Delay______6 _____
Refresh to ACT Delay________42 ______
Read to Precharge Delay_______4 _____
Memory Performance Enhance__________ [Normal]
High Speed DRAM DLL Settings________ [Option 1]
System Voltage Control____ [Manual]
DDR2 OverVoltage Control__ [+0.20V]
PCI-E OverVoltage Control_ [+0.1V]
FSB OverVoltage Control___ [+0.1V]
(G)MCH OverVoltage Control [+0.1V]
CPU Voltage Control_______ 1.45
Drop youre multiplier to 7 and crank it up should be able to get 480 on that board. My 6300 did 3.4 on that board at 486fsb and mem at 970. just fiddle with it is all
I wouldn't suggest using anywhere close to a 480 FSB on that board unless you do something to cool the northbridge and possibly the southbridge.
Robust Graphics Booster___________ Auto
CPU Clock Ratio (Note)____________ 6
CPU Host Frequency (MHz)__________ 420
CAS Latency Time_____________ 4 ____
Dram RAS# to CAS# Delay______ 4 ____
Dram RAS# Precharge Delay_____4 ____
Precharge Delay (tRAS)________12 ____
ACT to ACT Delay (tRRD)_______Auto _____
Rank Write to READ Delay______Auto _____
Write to Precharge Delay______Auto _____
DDR2 OverVoltage Control__ [+0.40V] = 2.1 Volt. recommended is 2.2 volt
CPU Voltage Control_______ 1.3500
But I have noticed (AND THIS COULD BE IMPORTANT TO NOTE) that the voltage in CPU-Z fluctuates by over ONE Volt keeps going up and down?????
CPU Clock Ratio (Note)____________ 7
PCI Express Frequency (Mhz)_______ Auto
DRAM Timing Selectable_______ [Auto]
System Voltage Control____ [Auto]
DDR2 OverVoltage Control__ [Auto]
PCI-E OverVoltage Control_ [Auto]
FSB OverVoltage Control___ [Auto]
(G)MCH OverVoltage Control [Auto]
CPU Voltage Control_______ [Auto]
Try that? I know it's going against all OC rules by not adding more volage to the RAM.. but mine only messes up once in a while.. so long as I keep the computer on and not restarting it alot.
Thus, I can get the e6300 to run at 3.15ghz.. but it's pretty hot.. 60 degrees C with a zalman 9500?
Then you should already know the max multiplier for the E6300 is already 7.... the 8 was just an example.
Also the P965 board with the northbridge that board has can be done on passive cooling so long as you have good airflow even with a FSB of 486.
