C2D and firewire?
se4b4ss
What's a good and relatively cheap motherboard that supports C2D (e6420) and has onboard firewire?
Thanks,
Steve
Looks like that board and the few others I found on newegg.com only have 1 firewire port. I have a video camera with firewire and would like to get an external hard drive w/firewire for music storage/backup when I build a new system so 1 port wouldn't quite cut it.
I think I'll just pop a PCI/firewire card in there. That leads me to another question, can those cards provide the bandwidth of an onboard firewire port being as though they are plugged into the PCI bus?
Well actually your online devices though convienient and on the mobo communicate using the same bus though with PCI in most cases a seperate bus. So they have the same limitations for overall bandwidth as PCI or PCIE depending on the mobo. (pciE of course is much less restricted.)
I too am thinking about getting a firewire card for my box at home. But I do want PCIE for the bus bandwidth available and I would also want headers on the card to enable the front port on my Sonata II case.
PCI bus bandwidth = 133MB/sec
Firewire 400 = 50MB/sec
You'll be OK unless you're really loading up your PCI bus during transfers.
PCI Express x1 = 500MB/sec
abit AB9/AB9 Pro & MSI P965 are probably a few of the cheapest 965 chipset mobos with onboard firewire.
That's good info. I'll just go with a DS3 MB and install a PCI/firewire card. Thanks for everybody's help.
MSI P6N Platinum 650i-based board - eSATA rear IO connector (faster than firewire), plus firewire rear IO, plus on-board header for front-panel firewire IO.
New Gigabyte GA-N650SLI-DS4 650i-based board - no eSATA on rear, but also has firewire on rear, plus 2 on-board firewire headers (one for front panel, additional one for rear).
Both also support SLI, if you want that option for the future.
