C2D + 680i -- best air cooling?
Blue3ffect
So, I decided that I just had to give the 680i boards a go to test out their performance because I just had to know... and besides that, I saw one listed in the For Sale forum for a ridiculously good price and, while I could have turned around and sold it for upwards of $50 more than I bought it for, I suddenly found that I had bought a C2D and was looking at some ddr2 800 ram for it.
Anyway, to the question at hand. I have an evga nvidia nforce 680i sli motherboard and an e6600 processor. What should I use to get the best cooling performance on air?
Note: I do intend to overclock the system.
Thanks for the replies. I think Ive done business with both of you, at least with bail for sure once or maybe twice, heh
Anyway, I think I'm going to go with a tuning tower. Seems like it would provide some top of the line cooling for my overworked little 6600 :cool:
The Scythe Infinity is slightly better by most reports. You really can't go wrong with either.
I tired both heatsinks, and Tuniq Tower performs better.
IMO my take on it
Tuniq
Infinity
Ninja
in that order... Tuniq comes on top not only for it's temperature, but it looks really awesome too... They're all on Jab-tech.com if you can't find one or the other.
hey fellas, another question related to this tuniq. Is the fan it comes with what you are using, or do you recommend an alternative? (apologies if this is jacking the thread, but you are discussing the tuniq above).
Included fan is PERFECT. It is a "special" 9 blade fan and it is only recommended that the user changes the fan with another 9 blade fan and nothing else.
The included fan is also another reason why the Tuniq Tower 120 better liked than the Thermalright Ultra 120, since the latter will cost you $50 and the fan is not even included.
Great Cooler though!
Thermalright Ultra 120 won't mount on that board (tried it myself). The eVGA 680i has some capacitors on the underside of the board that conflicts with the backplate. Confirm that the backplate for the others is compatible (or can be easily modified if made of plastic) before purchasing.
I just decided to sacrifice a decgree celsius (possibly two) and forego the backplate problem. . . got a Thermalright SI-128. It mounts via standard LGA-775 pins. No problems whatsoever.
I have a Scythe Infinity and it does a great job, lets me OC (currently testing 500x7 E6600) and its silent.
Can't speak of any others b/c I don't own them.
Thanks! I was at a few sites today and everyone was sold out. I was just going to post when I got home asking if anyone knew where I could find one.
No worries, its a good question thats related :)
Ive heard good things about the tuniq from everyone, so I think I'm going in that direction for sure. Thanks for all the help guys, greatly appreciated.
I have a Tuniq Tower 120 cooling a E6400 clocked to 2.4ghz and Motherboard Monitor CPU temperature is exactly the same as case temperature (34c)
Core Temp reports 42c for core 0 and 39c for core 1
With Intel Temperature Analysis Tool I can make the cores climb to 57c (45c on MBM) and about two minutes after I stop the TAT the cooler will bring the CPU down back to idle temperature.
When I get a better motherboard for overclocking I'm sure this cooler will help me get some very nice speeds.
Blue3ffect said:
what are your room temperatures?
Thanks!
Exactly,
An oc to 2.4 is just stock E6600 speeds, not really a good indication for 3Ghz+ speeds. I am 100% certain my Scythe would do that.
Its up past 60 I think there would be a bigger difference over my Scythe
Do you guys know of any place that has the TT120 in stock? I had ordered one from NCIX a month ago but it is still not in stock, and they estimate it will be at least another month before they get any in. I am up here in Canada.
Ive been looking myself, though Im located in Phoenix, Arizona. If anyone knows of any place that has them in stock, that would be awesome.
Im on jab-techs email notify and got an email from them around noon today. However, by the time I check my email now at 6pm, they are all sold out again. :( heh
