C1 error on DFI x58 Jr.
d50man
I'm getting a C1 error and no post on the DFI x58 Jr.
Tried resetting CMOS via jumper and hotkey also by pulling the battery.
Swapped know good ram and processor and i'm having no luck booting.
Any ideas before I send it out for RMA on monday?
Btw,
Processor is i7 930,
Memory is 3x2GB Muskin Radioactive CL6 1600 (PSC) and
3x2GB OCZ i7 black CL8 1600 (Micron)
GPU is GTX 285
Power Supply is ThermalTake Toughpower 750W
Storage is Several Western-Digital Black 640GBs and Green 1TBs
I just had the same problem with this mb.
C1 error is related to a memory problem.
Did you have any recent hardware changes?
Were you in the middle of adjusting your memory timings?
My C1 problem happened when I added a new set of G.SKILL PI Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7T-6GBPI.
I think the bios got corrupted. That is what I'm hoping for.
I'm going to see about buying a DFI Biosecure bios programmer to reinstall the bios.
It's the only method that I know of to flash a bios on this mb when the bios dies.
http://www.dfi.com.tw/portal/CM/cmp...sWindow?action=e&windowstate=normal&mode=view
c1 has to do with detecting memory...go to the dfi website and download the online manual and in the back under troubleshooting c1 has to do with memory detection..i would try doing a minimal boot with 1 stick of memory and see if it detects it....the online manual has the codes the printed one does not..
i bought a spare bios chip on ebay all programed with the latest bios....$8.20 and like 4 bucks to ship..brand new chip..its replaceable on this board...ive got the full atx version of this board and i really like it..
it runs cool in comparison to the 2 other x58 boards i tryed first...also try doing a long clear on the board like over nite...no power supply plugged in and battery out and jumper set...if you cant find a bios chip i have the seller on ebay pm me if you need it and ill send the link to your email or i can send you mine this week and you can buy me one and send it to me...whatever....pm me if u need any other info..
@wesleys_dad i know that C1 is memory BUT the memory is verified GOOD
spare bios chip sounds nice if that will fix it.... but with no post i'm leaning to RMA and if they say it was bios i will purchase a spare chip for the future.
I tried that and it didn't work. I only did it for about 1 hour though... I'm going to try it all night.
How hard is it to change out the bios chip?
Do you think taking out the BIOS chip and doing a long power drain for a few hours will help?
I'm going to get some spare chips and a Biosecure programmer.
SonDa5 have you had any other problems with this board?
Mine was an RMA replacement board and it only had 5 or 6 reboots on it from installing os, updates, and drivers.
The other board of mine blew the PWM at stock settings on a 920
Looks like 2 more weeks down without a game box....: (
I havn't had any other problems. The MB has been a flawless over clocking memory tweaking machine. :D
I have an RMA set up for my MB as well but I would rather just swap in a new bios chip or reprogram it if possible.
I have an idea though.... :eek:
I have a DFI P45 JR that works great. I read about doing a hot flash and am thinking about trying this.
To do this I will boot into Windows XP on my DFI P45 JR then remove the P45 BIOS chip (which I think is the same one). After removing it I will carefully put the corrupted X58 BIOS chip in the DFI P45. Then use Winflash and flash the X58 BIOS chip.
Do you think it will work?
depends on if the bios chip as the same pin layout.
I have hot flashed other mobos in the past i don't have one with a similar cmos chip holder
Found another possible solution that requires use of a floppy drive.
Posted by El Greco at XS.
http://www.xtremesystems.org/forums/showpost.php?p=3902007&postcount=10
i do not know if it helps but read ..
http://www.biosman.com/biosrecovery.html
BIOS Recovery
AMI BIOS
AMI has an embedded recovery technique in the 'boot block' of the BIOS. In the event that the BIOS becomes corrupt the boot block can be used to restore the BIOS to a working state. The routine is called when the 'system block' of the BIOS is empty or corrupt. The restore routine when called will access the floppy drive (1.44Mb floppy disk drive) looking for a file named AMIBOOT.ROM.
This is the reason the floppy drive light comes on and the drive appears to be in use. If the file (AMIBOOT.ROM) is found it is loaded into the 'system block' of the BIOS to replace the corrupted information.
BIOS recovery
Award BIOS
The AWARD BIOS has a similar procedure to AMI. To recover an AWARD BIOS you will need to create a bootable floppy diskette and add the desired BIOS file (we recommend using the most recent). Award BIOS's generally are in .BIN format, where as AMI was .ROM format. You will also add an AWARD flash utility (usually awdflash.exe) and an AUTOEXEC.BAT file.
The AWARD BIOS does not automatically restore the BIOS information to the 'system block' like the AMI BIOS does. You will need to add the commands necessary to flash the BIOS in the AUTOEXEC.BAT file. The system will run the AUTOEXEC.BAT file, which contains the flash instructions
I can give the method a try i just need to digggggggggg deep for a working floppy drive will report back asap
I threw a floppy dirve away a few years ago. Thought I would never use it. :(
Keep us posted. :)
1 out of 4 drives worked, after making the disk and reading it back on another machine but the board did NOT restore bios!
looks like its shipping out monday afternoon
That sucks.
My DFI P45 JR T2RS has the bios chip soldered to the MB. I thought it had a removable chip. :(
So no hot flash attempt. I'm going to have to send it in for RMA as well. :(
At least I have my DFI P45 JR to play with while the X58 Jr is being fixed.
what a bummer dude..my bios chip is on its way today although ill have to say ive flashed my bios probubly 10 times with a bootable usb jump drive and it works flawlessly...i just want a spare as i usually do with all my personal rigs...this board has been nothing but a pleasure to use..my favorite of all the boards ive had to date...im sorry i didnt purchase the jr version before they were gone, they has some awsome prices on them to get rid of them...
hopefull its not the memory controller on your cpu thats bad..most likely board or corrupted bios...
how high were your o/clocks and what voltages were you running?
No overclocks here yet, had installed win seven and all windows updates including sp1 then loaded the nvidia driver on that reboot it took a dump.
Hope its not the cpu too that would suck just got it form a member here.
also fresh memory.
It was a stable OC that I had ran with another set of the same rated Gskill sticks. My problem was caused as soon as I stuck in a new set of Gskill ram. I had justed passed memtest with no problem at stock speeds then went into bios and changed profile of ram to a speed that I had ran my other set on. As soon as saved ram timing setting and booted it froze at C1. I don't think the problem is with the cpu. I don't have an extra cpu laying around to test though. But I doubt the memory controller went bad because all me temps and voltages were safe.
How did you fix your bios with a usb stick?
any updates dfi is being slow to contact me again might get an RMA number before friday
The board was shipped to ITOX in New Jersey for RMA and they have had it since March 31st.
I was told they inturn shipped it to china/taiwan to thier factory for REWORK for a mofo C1 error?
I was told that i would have a 2week turn around time.
Just got the board back they are listing the fix as a bios data recovery
still putting the bos back together will report findings in a sec
it works reinstalled win7 64 going to oc it in a lil bit after i get wall the watercooling parts out of storage
you ought to get a spare bios chip and keep it on hand..i got one for the T3eH6 for like 8 bucks...
if u need the retailer pm me...
glad to hear all is good...what was turn around time on the board?
Did you get your MB back?
I just got mine back. Took about a month for me to ship it out to New Jersey and then for Itox to ship it to Taiwan then for it to come back to me. As soon as I get some time I'm going to put it in my RIG and lay the DFI P45 JR to rest for awhile.
Looking forward to tweaking it. I hope it is ok.
