C programming Question
JC724
So I am trying to practice creating linked list. I run into a bug immediately using scanf. I am using a printf statement followed by a scanf but it seems to be working backwards. Like the printf s will not run until after scanf. Which is really weird to me.
#include<stdio.h>
//linked list node
typedef struct myList {
int info; //data info
struct mylist *link; //self reference link
}Node;
int main()
printf("Starting\n");
Node *a = (Node*)malloc(sizeof(Node));
Node *b = (Node*)malloc(sizeof(Node));
Node *c = (Node*)malloc(sizeof(Node));
a ->link = NULL;
b ->link = NULL;
c ->link = NULL;
//this section is working backwards
printf("a data = ?");
scanf("%d", &a->info);
putchar('\n');
return 0;
terminal output:
1(input 1 here)
Starting
a data = ?
Starting and a data =?, should be printing 1st??
What compiler are you using?
As written your code works fine, here is my output:
You can try flushing the output before the scan I suppose
Standard output is buffered unless you tell it not to be. That means it won't print until there's a newline or the buffer is flushed. You can either set stdout not to buffer using setbuf(stdout, NULL); or call fflush(stdout); after your printf call.
