C++ help
Status
Not open for further replies.
Sanada
Can anyone help me out. I need to write a program that prompts the user to enter five test scores, and then prints the average test score. Can anyone help out?
you need to try it yourself first, we're not here to do your homework for you, we'll only help you if you need it, try it first and if you fail then post your code or something....
see the sticky. with all due respect, it's not the most difficult program
Code:
read score 1
read score 2
read score 3
read score 4
read score 5
calculate average score
print average score
Seriously, man, just try it until you get it. It can be done in a couple of lines of code if you play your cards right. =/ Once you do it, you'll get the satisfaction of knowing you figured it out by yourself.
Status
