tacosareveryyummy
- Jul 25, 2005
Just to clarify, this is in no way connected to any class or graded assignment. I am writing a program that will enable me to numerically compute color ordered spinor helicity amplitudes efficiently using the spinor helicity formulism.
My problem is thus. I define 4 separate 4 vectors for use in the evaluation of several expressions. Within each expression there are square roots. The values inside the roots can take on negative values (based on the assigned vectors) and cause the square roots to be imaginary. I am not sure how to implement this into the program. The program must also work for roots that are not imaginary. My head hurts. It's probably very simple I just need a break.
Any help would be appreciated.
Code:
//06/15/09
//This code will build the helicity amplitudes from the provided 4-vectors
#include<iostream>
#include<cmath>
#include<iomanip>
#include<complex>
using namespace std;
int i = sqrt(-1);
char choice;
class vectors
public:
int vect1, vect2;
double p01,px1,py1,pz1,p02,px2,py2,pz2;
vectors();
void input();
double squarebracket();
double anglebracket();
double roundbracket();
vectors::vectors()
void vectors::input()
cout << "Specify the vectors you wish to use. Enter choices 1-4" << endl;
cout << "Enter vector one." << endl;
cin >> vect1;
cout << "Enter vector two." << endl;
cin >> vect2;
if( vect1 = 1)
p01 = -1;
px1 = 0;
py1 = 0;
pz1 = 1;
else if( vect1 = 2)
p01 = -1;
px1 = 0;
py1 = 0;
pz1 = 1;
else if( vect1 = 3)
p01 = 1;
px1 = 0.5;
py1 = 0;
pz1 = 0.5;
else if( vect1 = 4)
p01 = 1;
px1 = -0.5;
py1 = 0;
pz1 = -0.5;
else if( vect2 = 1)
p02 = -1;
px2 = 0;
py2 = 0;
pz2 = 1;
else if( vect2 = 2)
p02 = -1;
px2 = 0;
py2 = 0;
pz2 = 1;
else if( vect2 = 3)
p02 = 1;
px2 = 0.5;
py2 = 0;
pz2 = 0.5;
else ( vect2 = 4);
p02 = 1;
px2 = -0.5;
py2 = 0;
pz2 = -0.5;
cout << "Specify whether you want [], <>, or (). Enter A for [], B for <>, or C for ()." << endl;
cin >> choice;
double vectors::squarebracket()
double squarevalue1 = 0;
double squarevalue2 = 0;
squarevalue1 = (py1 + i*px1)*sqrt((p02 - pz2)/(p01 - pz1));
squarevalue2 = (py2 + i*px2)*sqrt((p01 - pz1)/(p02 - pz2));
cout << squarevalue1 - squarevalue2;
double vectors::anglebracket()
double anglevalue1 = 0;
double anglevalue2 = 0;
anglevalue1 = (py2 - i*px2)*sqrt((p01 - pz1)/(p02 - pz2));
anglevalue2 = (py1 + i*px1)*sqrt((p02 - pz2)/(p01 - pz1));
cout << anglevalue1 - anglevalue2;
double vectors::roundbracket()
double roundvalue1 = 0;
double roundvalue2 = 0;
roundvalue1 = sqrt((p02 - pz2)/(p01 - pz1));
roundvalue2 = sqrt((p01-pz1)/(p02 - pz2));
cout << "(m_" << vect1 << ")" << roundvalue1 << " + " << "(m_" << vect2 << ")" << roundvalue2 << endl;
int main()
vectors vector;
vector.input();
if (choice == 'A')
vector.squarebracket();
else if (choice == 'B')
vector.anglebracket();
else if (choice == 'C')
vector.roundbracket();
else
cout << "That is not a valid option." << endl;
