I want to create a void function that can input strings (read from a file) into a series of character arrrays, which I have defined within a struct. Then I need to be able to use the struct char array within the block I have called the function in, and then have that struct char arrays destroyed once it leaves the block. I need them destroyed so that I can use the struct char arrays for different strings.
Is this possible in c?
I'm guessing that this is possible if I use an inline function. If so, am I right in saying that I can use variables defined in main within the inline function?
Sorry if the above makes no sense what so ever!
