I'm not sure if any of you are aware, but Westwood is known for horrendous online coding and the such. Anyway, while attempting to play a game of Generals with a friend, I ran into Westwood woes . At first, I couldn't even get to the part where you check for patches. After reinstalling, I was able to get past that and into the log in screen. When I try to log in, I get a message similar to: "Could not connect to Generals online" or something of that sort. I forwarded all the ports that I found I was supposed to on the web. No luck. I applied virtual DMZ. No luck. Anyone got ideas?
