c/c++ Arugment List
zappa86
How can I creating a function like printf that cant take unlimited arguments. I want to make a functing called Logger_Print and have it do what printf would basically do and more. I know you need to do something with the ... inorder to make it take many arguments.
Code:
void Logger_Print(int Type, char *Text, ... /*Hopefully a list of arguments */) {
	switch(Type) {
		case 0:
			fprintf(Logger_OutFile, "Verbose: ");
			break;
		case 1:
			fprintf(Logger_OutFile, "Status: ");
			break;
		case 2:
			fprintf(Logger_OutFile, "Notice: ");
			break;
	fprintf(Logger_OutFile, Text, /* The list of arguments passed to this function */);
Please let me know if you know how to add the argument list for the Logger_Print to the fprintf call in the function. Thanks.
Here's a good place to read up on variable argument lists. Here's a quick example I wrote showing how to use them:
Code:
#include <stdio.h>
#include <stdarg.h>
void print(int n, ...);
int main() {
    print(10, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10);
void print(int n, ...) {
    int i;
    va_list va;
    va_start(va, n);
    for (i = 0; i < n; ++i)
        printf("%d ", va_arg(va, int));
    va_end(va);
Honestly, I don't know if it is possible to carry out everything in Logger_Print() using your strategy. For you see, va_arg() must be called every time you want to fetch an argument from the variable argument list, and printf() itself must be passed all of the variables at once.
just use vfprintf. I used vprintf here because I didn't want to cook up a file handle for an example:
Code:
	switch(Type) {
		case 0:
			printf( "Verbose: ");
			break;
		case 1:
			printf("Status: ");
			break;
		case 2:
			printf("Notice: ");
			break;
	va_list valist;
	va_start(valist, Text);
	vprintf(Text, valist);
int main(int argc, char* argv[])
	Logger_Print(0, "%d, %d", 3, 5);
	return 0;
