C/C++, << and | in variable definitions?
Deathheadmoth
Hi, I have a question about something I've never seen used before in C or C++..
If you do this:
int test = (3<<2);
And then cout test, you get 12.
What does that mean? I've never seen << used in defining a variable.
Also, if you do this:
int test = (3<<2) | (5<<1);
You get 15.
Again, I'm not following what's happening. What is | doing?
The reason I'm asking is because I saw someone try to define an IP address as this:
long IP = ((155<<24)|(246<<16)|(14<<8)|11);
I know an IP address is 32 bits, so it seems like its storing the 155 in the first 8 bits, 246 in the second, and so on.. but how does this actually work? What do the operators mean?
I tried googling this stuff, but it's not a very easy thing to google
Thanks in advance for your help.
<< is the binary left-shift operator.
X << Y left-shifts X by Y places in binary.
3 (decimal) = 11 (binary)
if we shif it to the left twice, we get
1100 (binary) = 12 (decimal)
I is inclusive-or.
(3<<2) = 1100 (binary)
(5<<1) = 1010 (binary)
1100 | 1010 = 1110 (binary)
1110 = 14 (I'm assuming you meant 14 and not 15.)
lshift by x (number << x) is the same as multiplying by 2^x and is usually faster than doing a multiply or divide.
If you were to store an IP address this way, what would be the best way to extract the IP address from the long?
long ip;
// ip is a.b.c.d
int a = (ip >> 24) & 255;
int b = (ip >> 16) & 255;
int c = (ip >> 8) & 255;
int d = (ip) & 255;
Doing shifts is neat, but it can be slow.
Code:
long ip;
// ip is a.b.c.d
int d = (ip) & 255;
// most platforms use four bytes for "int", so you're wasting a lot of space for
// your expanded storage. Doing the shifts is pretty slow.
// if you know the endianness of your platform, you can easily make an array;
unsigned char* p = &ip;
// now, you don't have to do any shifting, and you can find the components
// in an interesting way. These offsets are for little-endian machines (like x86)
// p[0] is the same as d
// p[1] is the same as c
// p[2] is the same as b
// p[3] is the same as a
