I don't. How do I install it?generelz said:If you have the JDK installed on your machine (which you could test by typing "javac" at a command prompt), you could compile this and run it by doing "javac SQLConvert.java" followed by "java SQLConvert".
It's entirely possible I've got a bug, too. If I can run yours, then compare, then I can figure it out. Or, you can compile and run the code I've posted and compare it locally.generelz said:Hmm looking at my output it is 378,790,844 bytes. I wonder what the discrepancy is. Did I miss something?
