Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I purchased a 19" LG monitor a few days ago, and I noticed that it is making a low buzzing noise that can be heard from its sides/rear. Is this normal?
its ur screen its a faulty monitor. it happens. it happens to mostly older monitors when there about to give out. i would say return it and get a different one. if it continues to keep doing it report it to the companya nd if they say that its normal tell them that you would like know why its buzzing then if its normal. my momitor doesnt buzz. if they dont know then return it and buy a different one. that means that if the monitors that u buy from that company keep dooing that, that means that that shipment of momnitors was faulty
is it flat screen? if its flat screen RETURN IT! this year of flat screen monitors in all companies for some reason dont work like they should. but ya return it for a different one. i sugest a 17" View mate model 7 monitor. thats the one i have on my other computer and its seems like a very good monitor. im not sure if you can get it in stores i got mine off and ebay store. you could try your nearest electronic store.
i figured out what might be buzzing. in the monitor thers power cabels and chips and stuff. if theres not a good comection with the power it buzes. but it might now be that if its new. just return it for a new one
